kodiakcanuck
Jun 14, 2013Explorer
rockhillmanor wrote:
You won't be able to and should not use the Air Conditioning. And using it and other items at the same time and letting it blow breakers and resetting them is not the answer nor is it a smart thing to do.
Agree with this, you CANNOT run your A/C on 15amp. If you do manage to have all other power off and get it started, you will damage the unit by running it on low voltage over time. Lots of people will tell you can run A/C on 15 if nothing blows, but you shouldn't. Don't take the chance and blow your new unit.
You will be able to run everything else, including the microwave (as long as not a lot of other lights etc are on) When I camped on 15am, I ran the fridge and hot water tank on propane to save the amps for the lights etc.
Bring a stand up fan to keep you cool if it does get to hot at night.
44,071 PostsLatest Activity: Aug 16, 2026
