harddwn's avatar
harddwn
Duramax Deisel Questions
I have a 2006 LLY 2500 HD. I have installed and Edge Evolution programmer for the fact of monitoring EGT's. I've put the full 5" Turbo back exhaust. my mileage around town dropped but my pulling mpg went up. some say I don't have enough back pressure on my engine. when I had my stock exhaust system I could get 20+ mpg highway but 9.5 pulling with a hyper Tec power programmer. what are some thoughts as to my city mileage dropping
thank you
Jamie And Liz Axthelm
39' Yellowstone Canyon trail
  • If you are taking the mileage from the DIC it is probably incorrect due to the programmer. Only results to believe are hand calculated. If it's still off with hand calculation it could be the tune. Without a tune you should not have to worry about EGT's too much as your computer will defuel to keep temps down. Adding the tuner defeats that program. Best way to tune a d-max is by having your ecm reprogramed with EFI. Several guys are really good at it and can tune it to your specific needs. Check the diesel forums or look for Killerbee on this forum.
