Slate CM wrote:
myredracer, from what I have seen there isn't much out there that will fit that Jensen size opening. I also checked on the Kenwood car units and none of them have HDMI output. They do have a composite (yellow) video output.
If you are mostly using the tv while connected to AC power, you could look at home A/V units.
Worrying about HDMI output for DVD is a bit on the silly side. DVDs are only SD so any DVD player you buy that has a HDMI output has to SCALE UP the video (IE a built in scaler), good chance those cheapo DVD scalers will not be as good as the TV scaler.
Pretty much a wash and most likely the TV HAS A BETTER SCALER BUILT IN on the Composite video in.
If you really MUST HAVE HDMI then purchase a Composite to HDMI scaler.. Hook the Composite out into the scaler then hook the HDMI output of the scaler to your TV..
COMPOSITE TO HDMI SCALER
