jus2shy
Jun 28, 2015Explorer
I just invested in a spring clamp remover versus using vice grips. Makes the job of removing the spring clip lower on the CCV filter hose far easier, then you don't have to pop off that 10mm bolt. But yeah, just a minor inconvenience to go through the top. I don't even employ the ziploc bag. I find that the first inch or so of oil is siphoned out of the filter whenever I change the oil.
44,071 PostsLatest Activity: Aug 30, 2026
