- RvpapaExplorerIf you have Fantastic type fans set it to high blowing IN. With all other openings closed it will prevent smell from black tank.
Art. - navigator2346ExploreruTube is your friend
- mboppExplorerTwo bolts and a water connection, and the toilet comes off.
- mike_brezExplorersounds like a crappy job :)
- Old-BiscuitExplorer III
cavie wrote:
dcmac214 wrote:
Thetford Aqua Magic Style II
MUST the toilet be taken apart to replace the blade seal?
I replace the blade seal on my 310 tedfort in place. no tools required.
Sealand/Dometic 300 Series are designed that way
*Thetford doesn't make the 310
Not same set up with the Thetford Aqua Magic Style II like OPs toilet
OP ...
You can TRY to R/R bowl seal like 'mfinnerty' suggest
I prefer to separate the bowl/base and R/R bowl seal PLUS cleanup ball valve and check/lube the pivot points on ball - cavieExplorer
I replace the blade seal on my 310 tedfort in place. no tools required. - mfinnertyExplorerNot if you are careful removing the old seal and installing the new seal. I yank the old seal out using a needle nose pliers and then very carefully insert the new seal being sure to get the seal in the slot around the rim of the opening. You'll have to hold the blade back using the foot pedal while doing this. pay attention to the orientation of the old seal so you get the new seal in the same way.
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Aug 31, 2026
