Old-Biscuit
Nov 03, 2020Explorer III
cavie wrote:dcmac214 wrote:
Thetford Aqua Magic Style II
MUST the toilet be taken apart to replace the blade seal?
I replace the blade seal on my 310 tedfort in place. no tools required.
Sealand/Dometic 300 Series are designed that way
*Thetford doesn't make the 310
Not same set up with the Thetford Aqua Magic Style II like OPs toilet
OP ...
You can TRY to R/R bowl seal like 'mfinnerty' suggest
I prefer to separate the bowl/base and R/R bowl seal PLUS cleanup ball valve and check/lube the pivot points on ball
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Aug 31, 2026
