Cummins12V98
Jul 01, 2015Explorer III
I was think about the process and the first thing to do is to loosen the two big hose clamps, "THEN" remove the 10MM bolt "THEN" slide back the spring clamp pull the steel pipe out of the hose, "THEN" pull the intake tube loose at each end lowering it down then the steel pipe will drop down and slide out past the hose in front of the pipe and pull assembly out.
Easy Cheesy!
Easy Cheesy!
44,071 PostsLatest Activity: Aug 30, 2026
