cummins2014
Jul 02, 2015Explorer
Cummins12V98 wrote:rhagfo wrote:estesbubba wrote:Bionic Man wrote:
You know that there are some people on here that will argue that it is easier to change a tire on their tow vehicle because there is a better design on the (insert brand here) lugs.
You will never convince the troller that anything, especially RAM is on par with a beloved Blue Oval, so why try?
Exactly. I recently went to a diesel clinic at my dealer that has a top 3 Ram dealer in the nation, a #1 Ford truck dealer in the nation, plus a Chevy dealer. After the presentation and questions we all went into the shop and they had diesels from each where people could ask questions. Looking at them all side-by-side:
- The Ram had the most room to work under the hood
- The Chevy was a little more crowed
- The Ford was a freakin' cluster-f...
Of course someone on here has a cousin who's ex-wife's ex-husband knows a guy who works on diesels and said that Ford has the most room.
Ford DOES have the most room!! Once you remove the cab!
BAM!!!!!!!
I sorta illuded to that earlier.
And over the lifetime of changing filters on a Ram you will probably spend as much time as removing the cab on a ford :B
44,071 PostsLatest Activity: Aug 30, 2026
