Ed_Gee wrote:
Your campground host is in denial. He either has a wiring problem with his 'new' system, or it is simply over-loaded by all the campers plugged into the system. Not much you can do about it...and you're probably doing the right thing by not using your A/C if the voltage is under 108VAC on your meter.
Is that 5 campers each with 30 amps plugged into the same RV pedestal or fed off the same power utility company's pole ? Did they add more 30 amp receptacles to an existing pedestal?
It makes you wonder if it was done to Code and if done by a friend of the owner's friend. You know - the guy who's an electrician (wink wink)...
