myredracer wrote:
Ed_Gee wrote:
Your campground host is in denial. He either has a wiring problem with his 'new' system, or it is simply over-loaded by all the campers plugged into the system. Not much you can do about it...and you're probably doing the right thing by not using your A/C if the voltage is under 108VAC on your meter.
And it makes you wonder if it was done to Code and if done by a friend of the owner's friend. Ya know, the guy who's an electrician (wink wink)...
Some guy who camps there did the 30AMP upgrade and no I do not think he is an electrician. :E
