pianotuna
Aug 03, 2013Nomad III
Hi Drum,
There are no stupid questions.
The cord tends to coil as it is pushed in. If it is carry 30 amps @ 120 volts it may start to get hot because of the coiling. Therefore it is better to cut it off, leaving a couple of feet.
Drum wrote:
This may be a stupid question, but why cut the cord? You've got the male end at the hole anyway, so why not just plug it into a separate RV extension cable without cutting off the existing one? Then you've got extra cable to pull out in case you ever have a need for the extra length.
44,068 PostsLatest Activity: Jun 01, 2026
