Drum
Aug 03, 2013Explorer
pianotuna wrote:
Hi Drum,
There are no stupid questions.
The cord tends to coil as it is pushed in. If it is carry 30 amps @ 120 volts it may start to get hot because of the coiling. Therefore it is better to cut it off, leaving a couple of feet.Drum wrote:
This may be a stupid question, but why cut the cord? You've got the male end at the hole anyway, so why not just plug it into a separate RV extension cable without cutting off the existing one? Then you've got extra cable to pull out in case you ever have a need for the extra length.
Okay, that makes some sense. My next stupid question is: Does it really "coil" in the box? I have a hard time making a decent coil when I've got a whole cable from end to end. I was assuming that by pushing it back in the hole, it went in there as a jumbled up wad with air space mixed in. Still too hot?
I'm asking this not to argue, but I just bought a long 30 amp extension cable for hooking up to a far away source a couple of weeks ago, and I was considering doing this very thing for future outings. Plus, when I've got it hooked up at my house, there's only about 10 feet of the cable pulled out.
44,068 PostsLatest Activity: Jun 01, 2026
