Bumpyroad
Aug 06, 2013Explorer
pianotuna wrote:
Hi James,
As good as the Marinco is, they still may fail or disappear. That is why I chose to cut the cord and install a standard 30 thirty amp rv male plug. That way I can replace the long cord at any Walmart cheaply.JamesBr wrote:
I side with replacing the hatch and hole with a marinco twist lock kit.
yep, I'm not terribly thrilled with those Marinco twist lock connectors myself but they probably do hold together better than a standard 30/50 amp plug. Might be a reason to leave enough of the old cord so it will usually touch the ground and would be less likely to separate?
bumpy
