ScottG
Jul 27, 2014Nomad
There is no fuel efficiency to be gained from electric fans either. You Rams fan is free wheeling unless the ECM needs extra cooling and engages the clutch.
The one last point is that you CEL will always be on if you remove or disable the stock fan clutch - even if you left it plugged in somehow, it will fail for "rationality".
44,068 PostsLatest Activity: Jun 14, 2026
