Hi ScottG,
That is truly bad advice. Have you actually inspected a stab connector after it has been used for 1 month of constant use? I have, and it isn't pretty.
The stab connectors are garbage. Get rid of them if it is possible.
ScottG wrote:
Never had any problems with the so-called "Stab connectors" in any RV and running a space heater. Been doing so for a couple of decades and never had one get warm. They are UL and CSA rated for the full load just like normal residential outlets and there are 10's of millions of RV's using them without issue.
So I would not worry about changing the outlets, just monitor for heat like you should with any space heater.
