bkenobi wrote:
Clamp meters only work on AC, so I assume you are connecting the clamp at the TC panel or house panel or something? A Kill-A-Watt would worm too. I suppose I could do the same with a fuse buddy. But that wont test what's going to the jacks, only what's being pulled from shore. And since ground power is 15A unless you have a 30A outlet, I wouldn't expect you to pull more that 15A on a 15A circuit.
Nope, clamp meters come in both AC and DC. Mine has both. I have a FLUKE 365 detachable jaw meter. The detachable makes it easy to get deep into an area where the wire you are attempting to measure lives and still be able to read the display.
