bkenobi's avatar
bkenobi
Electric jacks and power
My 2007 NL has Happijacks installed on it. I've found that when raising and lowering the camper that the process can really drain the battery and the dealer confirmed with some numbers. I thought that perhapse disabling the batteries with shore power would be a good way around the problem, but then the jacks don't work at all. From reading and talking to the Happijack, the batteries are required due to current draw.
That sounds legit...except that I left the camper at the dealer for 2 months and the battery was flat. They plugged in a shore line and had no problem loading. I didn't notice if it was 30A or 15A.
Also, how can the jacks pull that much current when the DC wiring is all tiny? A car jumper cable is designed for heavy current and is very thick, but the jack wires in my unit are fairly small by comparison.
http://assets.bluesea.com/files/resources/newsletter/images/DC_wire_selection_chartlg.jpg
Acording to this chart, if the wore was 10awg and allowed to drop below 30A, it could be up to 30ft. But the claim I've heard is that the jacks can draw more than double that. If so, that would require 6awg or 4awg. I know the wires aren't 1/4" thick plus insulation.
  • 40 Amps for the 2-4 minutes running the jacks shouldn't drain the battery. 4 minutes is less than 3 AH of capacity.
    You may want to have the battery tested to see what your capacity/health of battery is. It could be that the voltage sag on the battery is too much for your battery.
    Above is correct. The batteries on all of my previous campers have needed to be installed for the jacks to work. Plugging the camper in will deliver amperage to the batteries allowing jacks to work through the boosted battery.
  • Even though the battery was "flat" the jacks were still connected to the battery. It's a circuit logic thing not a voltage thing.
  • I'm betting that the battery has to be inline to provide power to the jack. IF you unhooked the batter when you disabled the battery. You broke the current flow.
  • Happi Jac calls for 40a supply from the battery to the circuit board. Assuming each motor draws equally (they won’t due to the differing weight each jack lifts), the individual current being drawn would be 10a.
    No explanation for “flat” battery being able to run the jacks unless the battery charging circuit is good for ~40a.
