pbody
Nov 27, 2013Explorer
Wow, thanks RoyB! That helps a lot. Guess I have a new hobby so that I can enjoy my other hobbies.
I'm learning a lot as the minutes go by. I should have mentioned that we'll be boondocking. I have a couple of 6 volt batteries (just installed) and a Honda 2000 generator (which has been sole power source until now). Plan is to use heated mattress pad through night instead of listening to noisy furnace.
So if I understand better now....when I'm on battery power only, the outlets in the camper will not even have power to them? Or are the outlets only powered with 12 volts so I can only plug in items that run on 12 volt?
44,066 PostsLatest Activity: Apr 10, 2026
