n0arp
Jun 29, 2021Explorer
Huntindog wrote:
My new Momentum has disc brakes. The difference is HUGE!
I will never go back to drums. They are 1950s technology.
A relic of the past. And I will note, that you cannot get parts for them at Autozone either.
The calipers are all based on old GM designs for Kodiak/Titan brakes. If those are who make the ones on your Momentum, you certainly can at least get all caliper components (including entire calipers, pins, seals and pads) from Autozone/NAPA/Oreilly/etc. But you have to use a cross-reference and not just tell them they're for a GD Momentum...
Other parts, like the hub assemblies, especially if integrated on your particular model, and the controller/pump assembly, aren't going to be stocked. But those are probably less likely to require rushed parts for maintenance/repair.
