GordonThree
Jul 10, 2014Explorer
hddecker wrote:
Also could be the ground, the toothed washers that go between the jack and the frame can become corroded and not provide a good ground. If you prove the switch is good try the jumper wire from the jack to the frame or better the battery.
I'll cast my vote for bad ground ... make sure the three bolts holding the jack to the frame are tight, or take 'em out and inspect that toothed washer mentioned above, maybe sand the frame around the bolt hole.
