gwwing2's avatar
gwwing2
Electric TC camper jack conversion
I have a Palomino Bronco 1251 that is prewired for electric jacks. Prewired meaning there are outlets for each Reico/Titan jack at the corners and the wires end up in a bundle near the battery. Currently I use the KISS system of cranking the jacks up with my electric drill. My wife thinks its probably good exercise for me, running around to each jack and raising (or lowering) a couple inches until I get the camper to the level I want. since I load and unload the camper by myself I am wondering if a conversion to electrics is worth the expense and possibly more problems with additional things that can go wrong. I also wonder if there is an advantage of the Happyjak over the Rieco systems. It almost looks like the savings of a total new install of electric jacks over kits could be recouped by selling the manual jacks. Other then the running around, the reason for considering electric is, I assume, would prevent the possibility of putting twisting forces on the camper during un/load. My site for storing the camper is not fully level so there are some issues there. I do store it on a frame with 8 adjustable jacks to keep it level. Any thoughts on this would be appreciated.
Thanks
