MFL
Apr 18, 2021Nomad II
ScottG wrote:
Sounds like you figured it out - the jack is using the trailer for ground and not the ground at the trucks 7 pin conn.
Personally, I would cut the connector off and wire it to my trailers battery like most jacks are.
Agree with Scott, it would be much nicer to have the jack wired to trailer battery. If you wanted to raise/lower the trailer front, it seems foolish, to have to connect to the truck to do so.
Jerry
