I have your same trailer, 2012 model. I have a Barker 3500. Has worked wonderfully, even though I bought it used. Real back saver.
One thing I would advise you to be certain of is buy one with the longest throw you can. Mine is an 18" lift and I wish I had one that was significantly longer (22" maybe). If the parking spot is lower in the front than the rear of the trailer (which seems to be the norm for my camping spots) the amount of boards needed to build up the area under the jack can be significant. Usually 3-4 2"x8" boards do the trick but there have been times I needed 6 or 7. Having that extended reach of 4" on the longer extending jack would eliminate much of that issue most of the time.
