dee74's avatar
dee74
Electric tongue jack
I have a 2014 Keystone Passport 238 ml. I am thinking about buying an electric tongue jack. I know the one in the link below is more than I need but I would prefer too much than just enough. Can anyone tell me if this would fit on my trailer and also would line up with the existing bolts on the manual jack?
3500lb electric tongue jack
  • Don't forget your tongue jack is not only lifting the tongue weight, it is also taking on some of the weight of the rear of your RV as you lift and remove load from the rear axle springs.
    Agree with above reply - get the beefiest one that will fit your trailer tongue.
  • There are two hole sizes depending on the size of your trailer. The holes will line up or your money back! We have a bulldog 4000# electric tongue jack that has sealed gears, no lubrication needed and a 5 yr. warranty if I remember. Our shaft did bend after a couple years of heavy use, so that it couldn't be extended its full length, and the company sent me a new one. I'd get the heaviest one you can buy!
