- mosseaterExplorer III use contact cleaner. Hose it down and while it's still wet, run the plug in and out several times. Let the contact surfaces make their own path. I agree with the dielectric grease also, just never used it myself. No issues in 8 years.
- westendExplorerCaig Deoxit D5 or Deoxit Gold G5 are what I use.
- Shadow_CatcherExplorerCRC electric contacts cleaner, nasty stuff that needs to be used in a very well ventilate area!
- CavemanCharlieExplorer III
DutchmenSport wrote:
Age old, time tested, been around forever cleaner solution for battery connections anywhere on an automobile, plugs, batteries, anywhere that green-white corrosion build up occurs:
Baking Soda mixed in water. Simply put the plug in the water and watch it foam everything off. Then rinse the plug with clean water! This is as old and timeless as the automobile! It's still the safest and it's still the cheapest.
You can make the baking soda into a paste and bush on with a small paint brush or pour on from a cup to. The thicker the better. Simple, easy, cheap and works.
I've used this on battery connections and it works great. - Dennis_M_MExplorerAfter they are clean put some dielectric grease on the connectors.
- DutchmenSportExplorerAge old, time tested, been around forever cleaner solution for battery connections anywhere on an automobile, plugs, batteries, anywhere that green-white corrosion build up occurs:
You can make the baking soda into a paste and bush on with a small paint brush or pour on from a cup to. The thicker the better. Simple, easy, cheap and works. - vermilyeExplorer III use DeOx Spray. While some use emery cloth or sandpaper, that will eventually remove the plating, making things worse.
