- Relay or not the RV and truck will be fine if connected while the RV is plugged in.
Worst case the truck battery will stay charged. - tvman44Explorer'02 F250 is disconnedted from RV by a relay when engine is off.
- M_R_E_ExplorerThank you for your replies. I was just going to do it the day before I leave.
- wing_zealotExplorerMFL has it right. You will not be affecting your truck battery at all unless the truck is turned on. There is no 12V power to the RV unless the key is in the run position, 02 Ford F250 have a relay.
- AllworthExplorer IIIt probably won't hurt anything, but I can see no good reason to do it. Why make the electrical system more complicated than necessary?
- NMDriverExplorerI was told by a battery wizard, that every battery in a system sinks to the level of the worst battery in the system. My Chevy is hot to the RV when plugged in. I am no battery wizard myself, but the odds of one of my house batteries being below optimum and pulling down my two truck batteries is not a remote possibility. I keep my truck batteries isolated from the 5er when not towing.
I also keep my truck running and hooked up to operate the slide, landing gear if I am not on shore power. Lessons I learned on my old truck, which needed every bit of amp the two batteries could provide to start. - WyoTravelerExplorer
sail2liv wrote:
My connection pins are hot all the time.....so if plugged in will drain truck battery eventually.....if using current over time....2500HD
I think you are right if 2500HD means chevy PU. Ford puts that line through ignition don't think chevy does. If I owned a GM product I would use a relay in that line. - sail2livExplorerKeeping unit plugged to 110 should keep house battery charged so little to no drain would occur on truck battery....
- sail2livExplorerMy connection pins are hot all the time.....so if plugged in will drain truck battery eventually.....if using current over time....2500HD
- MFLNomad IIUnless you have altered the charge line, in the Ford, the battery wire in the connector will be dead, without the key in the on position (engine running).
So yes, in your case, it would not matter.
Jerry
About Fifth Wheel Group
19,006 PostsLatest Activity: Jan 29, 2025
