sasquatchgeoff's avatar
sasquatchgeoff
Explorer II
May 26, 2016
Electrical Gremlins Eating me and my Battery Alive
With so few real clues to the problem, I know it is a long shot posting for help in this regard, but I will have a go at it any way.
About three weeks after getting back from a trip, I went to plug the bargman (pigtail) into the receptacle in the bed of the truck, and when I did, I heard a small 'pop' and then actually saw a little plume of smoke rising up from the barman plug/socket. Instinctively, I knew this meant trouble, but tested everything, including signal/stop lights and compartment 12V functions and it seemed to be normal. When on shore power, battery charges, everything works - except the backup lights.
However, after time I discovered (and this is the problem) that the only battery in my rig was not-so-slowly discharging at the rate of about one day and its dead. When boondocking I have to break out my generator and plug into AC 3 or 4 hours before bedtime to have a furnace to run all night. Its still pretty cold in the hills here.
I bought a new battery because the old one would not take a charge any more. This gremlin may have killed it, or maybe it was its time. I'll never know. With a new battery, I still had the dead-in-a-day issue.
So today, after determining that I indeed had a dead short somewhere in the camper, I broke out my trusty multimeter. Here is what I get when I test the power and ground at the Magnatek, as well as one each of the red and white 12V leads that attach to the battery terminals in the battery box. Apparently there is a short, since the conductivity registers, but shows a resistant connection when it should be, based on my extremely limited knowledge, no connection between the main positive and negative terminals.
Now, I get this same 1/3 of a dial worth of resistance on the ohmmeter when testing the backup light pin (neg) and power pin (pos) on the bargman plug. Remember the backup lights no longer work.
I bought a new bargman plug and will install tomorrow before heading out on a trip to Central OR where in the hills, the night time temps can get down to the teens.
Any ideas, or suggestions, or even insults are entirely welcome.
  • zcookiemonstar wrote:
    as dumb as is may sound try removing the bulbs from your reverse lights and see if your problem goes away. I have had bad bulbs cause problems with low voltage controls.
    I thought of that after I posted. First thing on my list to check tomorrow...
  • as dumb as is may sound try removing the bulbs from your reverse lights and see if your problem goes away. I have had bad bulbs cause problems with low voltage controls.
