Driftwood132 wrote:
After checking for burnt wires, make sure the gen is outputting AC , just replace the ats, yes its hard to get to but you will be happy in the long run. Putting plugs and manual plugging in is a pain. And will cost more then the ats.
Some of the ATS (automatic transfer switch) have a reset... some have an indicator light inside the box... some have a setting that keeps you fom having a 30 second delay... read the literature supplied by your campers manufacturer before you tear into anything...
use your multimeter to make sure the gen power is getting to the ATS
chet
