time2roll
Jul 09, 2013Nomad
Battery should not run down when plugged in. The WFCO is either dying or dead. WFCO should hold 13.6 volts on the battery at all times. I would replace with a different brand. Go with IOTA, Progressive Dynamics or Powermaster. 30 to 35 amps is fine unless you go with more than two batteries. www.bestconverter.com
2000w inverter is huge power from a battery. You really need 400+ amp hours to run this size inverter in a practical manner.
I power my tv, dvd, laptop and charge small items with a Go Power 300w sine wave inverter.
I mounted the inverter behind the fuse-breaker panel. 12v connects to the main battery feed to the panel. 120v is wired into the entertainment area circuit with an automatic transfer switch. The wiring is very straight forward if you have done any home wiring before. The Go Power 300w has a provision for a remote power switch so with the touch of a button I have instant power.
GP 300w SW $172
Xantrex 15 amp switch $49
So all in maybe $250-$300 for self install.
GP 300w SW $172
44,068 PostsLatest Activity: Jun 01, 2026
