SoCalDesertRider wrote:
Sounds like a blown fuse, caused by whatever electrical short is resulting in the burning smell.
If it's coming through the vents with the A/C on, it could be the resistor inside the heater box.
Beware... that resistor likely caused the fire that burned one of my F350's to the ground....
That is the problem. No blown fuses that I can find. But definatly something went wrong within the electrical that needs to be repaired. So far the only thing I can find not working are the power door locks. But when you use the lock/unlock button on either front door or remote you can hear the radio.
