Sokniw's avatar
Sokniw
Electrical question on my Vintage Trailblazer camper
Hey guys, new to the forums im hoping im posting in an ok part of the forums for this.
So basically we got an old vintage Trailblazer camper prolly like 14-16ft, But there was no electrical on the outisde of the trailer hooked up, i have the wires but no outlets. In side it has a box with one of those old traditional screw in fuse's, but im not sure what i need to hook up on the side for Plugging into a post, and for the trailer lights.
lookin for a little direction.
and like i said, i have all the wires sticking out, i just dont have plugs/outlets.
Inside the trailer it has an outlet like you have in the house, no idea if its an 15a or 30a.
  • Yeah i started guttting it today, there is a box were i can access the electrical and i can see all the wires running under the trailer, like is aid this thing was sitting for liek 30 years, and all the wires were just shoved int he hole and filled with caulk.. lol prolly got water damage at 1 point and they just sealed it up.. Im going to put some pictures up soon. my wife has been taking pictures for a before and after type thing.
    But the answer i was looking for was the motor base plug.
  • Sokniw wrote:
    I have all the wires sticking out of the trailer, just no plug on the end of them. The trailer we got was sitting since 1979, and its in pretty good condition for a trailer that has been sitting for over 30 years. Frame and wheel bearings all still in working condition. A lot of the interior got water damage but the parts that didn't look brand new. I got a lot of tearin into to do, but i was wondering if there was a special outlet i would wire into the power wires that are coming out of the trailer and mount it onto the side for an external plug.
    Wellll,,,, If I understand you,, your asking questions a electrician should answer. If you just stick a plug on the end of the wires that are sticking out of there without knowing where the wires go you could easily make a huge fire and get yourself hurt. Not to mentioned electrocuted and dead.
    Maybe there is a reason the wires are cut off??!! You need to start over at this point, rip all the wiring out and redo everything in a safe way. You say you have water damage? You will be taking out the walls anyway. Might as well do it all the right way the first time and get it over with. (That's what my dad would have said)
  • You need a "motor base" plug. The non-marine ones can be found at big box stores or some rv places have them
  • I have all the wires sticking out of the trailer, just no plug on the end of them. The trailer we got was sitting since 1979, and its in pretty good condition for a trailer that has been sitting for over 30 years. Frame and wheel bearings all still in working condition. A lot of the interior got water damage but the parts that didn't look brand new. I got a lot of tearin into to do, but i was wondering if there was a special outlet i would wire into the power wires that are coming out of the trailer and mount it onto the side for an external plug.
  • There should have been a cord to plug in somewhere at one time. Somebody has stolen it. Take apart the box where the screw in fuse is located and see if you can find where the cord originally was. Then you will have to replace it with a new cord. You should find someone that knows about 110 volt power for this to be on the safe side. All the cord will do is let your outlet inside the trailer work. The lights most likely were run from 12 volt battery power. ( like a car battery) There should be a place to put a battery and the wires to hook it up. If not someone stole them too sorry to say. The battery was probably mounted on the hitch but, not necessarily for sure. I once had a old trailer that had the battery mounted in a enclosed box inside the trailer with a access door to the outside to pull the battery in and out of.
  • I had the same problem once and it took me a long time to figure it all out, so I will see if I can give you some clues. If your TT is old enough, many of the old ones used the siding to provide a neutral that carried the return from all the outside lights. Often the fixtures would work their way loose from the siding and then the lights inside the fixture would not work, or work oddly.
    You may have a brown wire, a green wire, and a yellow wire. Those are the positive feed to the rear lights. Connect your negative from a good battery to the ground on the TT, someplace on the siding or frame, and touch the positive to those wires to see what happens with the bulbs at the back.
    If nothing happens, then you should either find a way to see the back of the rear lights from inside the TT, or if necessary, remove them off the back of the TT and connect negative to the metal frame of the fixture, and positive to the filament leads to see if the bulbs work.
    Only once you get the actual fixtures working properly can you then try connecting your wires to an actual plug.
    PM me with your results from this and I will keep working with you. I have fixed many rigs and know how to fix brake/run lights that operate strangely with amazing results.
