JumboJet
Aug 20, 2013Explorer
irishgurl wrote:
The fridge is actually working, just very very quiet. The air conditioner sounds as though the compressor is coming on but no air is blowing out. The fan that I have plugged into an outlet seems to go slower when I put the AC on. Does it take a while? Shouldn't the fan option work?
I have checked all the fuses and all are OK. Even found the two 40 amp ones hidden under the obvious fuse/ circute box.
I really appreciate all of the responses. What a great group!!!
I had the same issue with my AC on a 2000 Class A. I swapped out the fan start/run capacitor and all is good. I would hear a hum from the compressor, but no fan. What I found when opening the cover to the capacitor's was a huge wasp nest, several dirt dauber's nests, and corroded contacts on the capacitors.
To do the above requires climbing on top and removing the AC shroud.
