beemerphile1 wrote:
powderman426 wrote:
dbbls wrote:
beemerphile1 wrote:
A properly wired disconnect in a travel trailer will NOT disconnect the breakaway switch. It is a safety issue in case the trailer is towed with the disconnect open.
Where does the power come from if not the trailer battery????? You are wrong on this.
No. He is correct on this. The breakaway wires should be routed around the cutoff switch otherwise it would be possible to forget to turn off the switch and be running with no brakes.
Correct. The disconnect is in the positive line and the breakaway is connected prior to the disconnect.
That is how I wire my trailers. The break away switch is always hot. It doesn't draw any current, unless it is needed, so it doesn't matter anyway.
