Big Love wrote:
You can insert the EMS anywhere between shore power (input) and the Romex cable going to your converter. In my case, there was already enough slack in the Romex running from the outside shore receptacle going to the converter so that I simply cut the Romex and then re-attached it to both sides of the EMS.
That is what I was wondering, could I use Romex from the outside shore receptacle to the input of the EMS and then connect the output of the EMS to the Romex that is already there going to the converter. If I can do that then can I not remove the black cable and metal box that is in the picture?
