dmullen wrote:
I wanted to use Romex instead of the black shore cable on the input side and was wondering if there is anything negative about doing it that way.
So ... you want to go from the pedestal to the EMS with Romex, right?
If this is a permanent site, go ahead. If you are touring, the Romex will be a PITA to roll up and store. Also, it is not designed to be flexed over and over.
I don't understand why you want to do this. Why is attaching the flexible shore power cord to the EMS a problem for you? Why would you not want to keep the power cord designed to
do the job
on the job?
Teach
