'tiredTeacher wrote:
dmullen wrote:
I wanted to use Romex instead of the black shore cable on the input side and was wondering if there is anything negative about doing it that way.
So ... you want to go from the pedestal to the EMS with Romex, right?
If this is a permanent site, go ahead. If you are touring, the Romex will be a PITA to roll up and store. Also, it is not designed to be flexed over and over.
I don't understand why you want to do this. Why is attaching the flexible shore power cord to the EMS a problem for you? Why would you not want to keep the power cord designed to do the job on the job?
Teach
I am not wanting to use Romex from the pedestal to the trailer. I have a normal black power cord for that. Instead of pulling the power cord out of the mouse hole on the side of the camper I replaced it with an outlet so now all I have to do is plug in the power cord on the outside. Marinco & Furrion both make these shore power conversion kits. The point of my thread is the wiring from the back of that outlet to the EMS to the convertor.
