dalehelman's avatar
dalehelman
Enclosed under belly
We once owned a Keystone trailer. The underside was covered with a black corrugated plastic. Does anyone know what it is called or where to find it?
  • RoyB's avatar
    RoyB
    Explorer II
    I have two or three spots under my trailers where I needed access to so I sort of cut the size hole I needed and covered it back up with a screw in panel of the same stuff so I wouldn't have to remove the whole underbelly cover. Made life alot easier here...
    Roy Ken
  • You can buy Coroplast in bulk and large sheets right in Spokane. Don't remember the name of the company. It's between Broadway and Trent, just east of the Fancher bridge. Googling netted me lots of results too.
  • Coroplast - my local homedepot sells it, but only in white
  • Sign shops, the ones that make campaign signs, will usually stock it in several colors.
    Or RV shops, of course. The RV stuff may be thicker?
  • It's called Colorplast and a quick Google search will yield several suppliers.
    Good luck,
    Scott
