hornet28 wrote:
BB_TX wrote:
Or install a tire pressure monitoring system and check regularly while driving instead of every 2-4 hours. Low pressure is not just going to conveniently happen at your rest stops and fuel stops.
You check pressure every 2-4 hrs?? If their losing pressure that fast I'd be changing tires. Just finished a 7500+ trip 7K+ on the trailer with Endurance and never lost a lb.
No. With a TPMS that alarms on low pressure I don't have to check the pressure. Although with the monitor sitting on the dash I can look whenever I want.
You may go years and thousands of miles and never loose a pound of pressure in a tire. Until that one time in the middle of a long drive you pick up a nail and pressure starts to drop without you knowing it until it is so low it starts to overheat and destroys the tire before you start to see smoke.
