RCMAN46 wrote:
I do not believe the diesels used in the pickups have true Jake brakes.
The braking is done with the turbo and not with valve timing as in the big rigs.
Ram calls it a Jake brake but it really is not a true Jake brake.
Well the Cummins 6.7 can be equipped with a true engine brake, PacBrake has a kit. That is not badly priced.
Pacbrake Loadleash Engine BrakeMy 01 with a after market PacBrake will slow well enough in Direct drive 4th on a 5 speed that I need to either release it or apply a little throttle.
BRULAZ wrote:
My 2011 F150 with the 3.5L EcoB has good engine/tranny braking in Tow/Haul mode, but on some steep and windy Appalachian trails I've needed to let it wind up to 4000-5000 rpm in first gear so as not to cook the truck+trailer brakes. From what I'm reading here, a similarly sized diesel without an exhaust brake would be worse.
Wow, and how fast were you still moving, lowest gear I have ever needed was 3rd, on my 5 speed, traffic was down to about 40.
