New TT user. I'm considering purchasing a Lance 2185 TT (https://www.lancecamper.com/travel-trailers/2185/specs/) or similar size and weight TT. Before I buy (used) I plan to rent one next month using...
you are correct. much better info than most who ask. Id go for it. You will be borderline but you are upgrading anyway. Either the 3.5 eco or the 5,0 will handle those fine. power is not the problem its payload. my 2016 f150 has the 5.0 and 1900 ish lbs payload. watch door stickers as they can be quite different truck to truck.
