myredracer
Jun 29, 2019Explorer II
Doesn't matter if it's an entry level or upscale fiberglass model, they can both have quality issues to deal with, minor to major.
Our first TT was a small aluminum sided unit with no slide and basic features and would have been considered entry level. Only issue was a problem with the brakes that the dealer eventually fixed. Our current TT is in the upscale category and has had plenty of issues from day one. Into our 6th season on it and am still finding significant bad factory workmanship issues to deal with.
Wood-framed versus aluminum sided TTs, either can actually be better in some circumstances. Like if the exterior gets damaged, you can replace rows of the metal. Wood framing is much more forgiving on rough roads - aluminum framing can have failed welds in comparison like we did below. If you camp a lot in cold weather and fail to remove moisture in the air, or have a leak on the exterior, you can end up with rotted wood framing or fiberglass delamination. Take your pick.
"Entry level" is like a starter home. Smaller, minimal features and lower cost. Maybe a single axle only. Some features are def. worth spending money on. Having a slide with sofa and more space was a huge plus for us.
Choose wisely, buy once... :)
44,066 PostsLatest Activity: May 13, 2026
