ZeeLet50's avatar
ZeeLet50
Equal-izer change.
Due to the fact I could not open my tailgate all the way when the trailer was hooked up I invested in a longer shank. Went from 12" to 18". Reset up system because the shank put my ball down 3/4" from previous height. Got it dialed in so front end is at same height as unloaded. Added 1 washer to tip the ball. Finished up late so did not go for a ride. Just wondering if the added length will change any characteristics. It did solve my tailgate issue. That is one heavy piece of hardware weighing in at 30lbs just for the shank.
  • If I ever need to bring the 4 wheeler with me it will not fit into the bed with the gate shut.
  • Your tow test will give you the answer...but, I'm not in favor of extended shanks. My experience...the closer the trailer is to the receiver the better it will handle.
    Why did you need to be able to fully open your tailgate?
