map40
Jan 06, 2023Explorer
way2roll wrote:map40 wrote:pianotuna wrote:map40 wrote:wnjj wrote:pianotuna wrote:
map40,
Which electric car will go 1500 miles on a single charge?
I took that to mean he’s driven 1500 miles and not had to use a public charger (i.e. round trips from home).
No, 1500 miles with no charging. I have never charged in a public charger. I have an EV that was designed propperly, with an on-board generator. 99% I use battery. 1% of the time I do a long trip I use the generator
In other words you made your BEV into a hybrid.
Without the complicated mechanics and the short range of a plug in hybrid (not a hybrid). Might sound similar, but it is a world of difference.
Always remember, an ICE is 30% efficient on converting fuel into motion. Parasitic loads, brakes converting kinetic energy into heat, they are all waste. An EV is 95% efficient converting power into motion.
As I said, they are a great alternative for the right use, but they won't replace all ICEs uses. And Trucks are the most difficult use for EV applications.
But to circle back around to your claim, you did not go 1500 miles without a charge.
As far as I care, I did. What is the biggest problem with EVs? Dealing with charging, finding the chargers and waiting 1 hour. I did not have to do that once. I did it by having an APU, but that is the compromise that makes it worth while. I ran the APU 5 times last year. That saved me from EVER HAVING TO WORRY ABOUT CHARGING, NOT ONCEDURING THE WHOLE YEAR. However you look at it, it eliminated the only problem I had with having an EV. Ask any EV owner, that is the biggest problem.
Forget politics, preconceptions and ideologies. If I offer you a car that is more efficient, that runs on fuel at least 5 times cheaper, that you can refuel at home and that you can drive it as far as you want, wouldn't that be a good deal?
As I said at the beginning, EVs are not the light at the end of the tunnel and they are not for everybody, but for the people that fit the use they are a great choice now.
Trucks...I don't see it that easy...
44,071 PostsLatest Activity: Aug 09, 2026
