RoyJ
Jan 06, 2023Explorer
map40 wrote:
As far as I care, I did. What is the biggest problem with EVs? Dealing with charging, finding the chargers and waiting 1 hour. I did not have to do that once. I did it by having an APU, but that is the compromise that makes it worth while. I ran the APU 5 times last year. That saved me from EVER HAVING TO WORRY ABOUT CHARGING, NOT ONCEDURING THE WHOLE YEAR. However you look at it, it eliminated the only problem I had with having an EV. Ask any EV owner, that is the biggest problem.
Forget politics, preconceptions and ideologies. If I offer you a car that is more efficient, that runs on fuel at least 5 times cheaper, that you can refuel at home and that you can drive it as far as you want, wouldn't that be a good deal?
As I said at the beginning, EVs are not the light at the end of the tunnel and they are not for everybody, but for the people that fit the use they are a great choice now.
Trucks...I don't see it that easy...
People like to rip on the i3, but I think it's the best design for an EV. A series hybrid if you will. Just a tweak in firmware like you did to allow the IC charger to run full blast and build up charge.
Towing aside, that implementation would work for 99% of commuters. Charge at home, and rely on the 30hp charger. Your *average* hp consumption is far less than 30hp during commute drive.
Call it whatever, hybrid, EV with IC charger, etc. But that approach can be applied to any commuter - Civics, small crossovers, hatchbacks. Way less complex than a Volt or parallel hybrid. A Honda CBR 500 type motor can be had for a $1 - 2k if mass produced.
44,071 PostsLatest Activity: Aug 09, 2026
