map40
Jan 09, 2023Explorer
Huntindog wrote:
A few days ago the Wall Street Journal had an article about what it presently takes for renewables to supply power 24/7.
Apparently it has been done on a small scale in several locations. The common theme was that it takes 3 times the capacity of a conventional power plant AND an incredible amount of batteries to achieve the level of reliability we are used to. They flat out concluded that it cannot be done with todays technology.. It would take too much real estate and cost way too much.
So we are going headlong down a road that presently has a bad ending.
Will a better way be developed?..... Maybe and maybe not. One thing is certain. Companies will only continue down this road if makes financial sense. Presently Governments are providing enough incentives to make it so. But even they cannot afford to do this at the level it will take to be green. One thing is certain. Buisinesses will not shoulder the cost alone, as long as they know it is not the ultimate solution. As they would be loath to pay for all the stranded costs of a failed experiment IF a better way forward is found.
There are a many reports in favor as there are against them. If what the reports against it say is true, why are all automakers going into it? NO AUTOMAKER WOULD GO INTO EVS IF THE REAL CASE WAS THAT BAD. Will it replace ICEs? NO WAY, THE TECHNOLOGY IN ITS CURRENT PATH CAN'T. When we learn to evaluate things objectively with no preconceptions or politics we will understand that EVs are just a variant type of vehicle that thanks to the advance of technology is now getting into the masker after 140 of being invented (remember, EVs are older than ICEs).
44,071 PostsLatest Activity: Aug 09, 2026
