Huntindog
Jan 09, 2023Explorer
map40 wrote:The automakers are being forced into it by the govt. with a carrot and stick aproach. The head of Toyota has pubilicly stated that the present path cannot succeed. He also said that many others in the biz say the same thing privately.Huntindog wrote:
A few days ago the Wall Street Journal had an article about what it presently takes for renewables to supply power 24/7.
Apparently it has been done on a small scale in several locations. The common theme was that it takes 3 times the capacity of a conventional power plant AND an incredible amount of batteries to achieve the level of reliability we are used to. They flat out concluded that it cannot be done with todays technology.. It would take too much real estate and cost way too much.
So we are going headlong down a road that presently has a bad ending.
Will a better way be developed?..... Maybe and maybe not. One thing is certain. Companies will only continue down this road if makes financial sense. Presently Governments are providing enough incentives to make it so. But even they cannot afford to do this at the level it will take to be green. One thing is certain. Buisinesses will not shoulder the cost alone, as long as they know it is not the ultimate solution. As they would be loath to pay for all the stranded costs of a failed experiment IF a better way forward is found.
There are a many reports in favor as there are against them. If what the reports against it say is true, why are all automakers going into it? NO AUTOMAKER WOULD GO INTO EVS IF THE REAL CASE WAS THAT BAD. Will it replace ICEs? NO WAY, THE TECHNOLOGY IN ITS CURRENT PATH CAN'T. When we learn to evaluate things objectively with no preconceptions or politics we will understand that EVs are just a variant type of vehicle that thanks to the advance of technology is now getting into the masker after 140 of being invented (remember, EVs are older than ICEs).
I installed solar on my RV. I think it is cool to be able to run a lot of my RV off of it. But seeing what it took for just my RV... I just cannot see how it can scale up to replace the power generation we now enjoy... Especially with the way we waste power.
Think about this: There are many companies with warehouses full of computers running nonstop.... To make imaginary money!
It is so bad that Musk stopped taking bit coin because of the amount of electricity being consumed to produce it!
44,071 PostsLatest Activity: Aug 09, 2026
