map40
Jan 12, 2023Explorer
way2roll wrote:map40 wrote:valhalla360 wrote:map40 wrote:
Without the complicated mechanics and the short range of a plug in hybrid (not a hybrid). Might sound similar, but it is a world of difference.
Always remember, an ICE is 30% efficient on converting fuel into motion. Parasitic loads, brakes converting kinetic energy into heat, they are all waste. An EV is 95% efficient converting power into motion.
As I said, they are a great alternative for the right use, but they won't replace all ICEs uses. And Trucks are the most difficult use for EV applications.
95% efficient is if you only look at the electricity arriving at the motor. Once you add conversion to and from the battery, transport over the grid, burning coal at the power plant, etc...even with the power used to drill, transport and refine oil, it's no longer the slam dunk in terms of efficiency.
In the same analogy, when you look into the efficiency of an ICE and include the refinery, transport, drilling, barreling, etc, the ICE drops below 5%. There is no merit in arguing that EVs are 3 times more efficient, you are picking a lousy argument that will not change the conclusion: For the right aplications, EVs are better than ICEs. Not all cases, just some.
Because EV's don't require mining, packing, transport etc right?
They both require a lot of resources, but the point is simple: for the right application EVs are vastly superiors to ICEs, just like Diesel engines are better than gasoline engines for some aplications. You are both complaining a point that is useless. EVs are built for efficiency and they are good at it. ICEs are built for convenience from 100 years ago, and although we keep improving them, there are applications for which the EV are going to be better than ICEs. And in those cases, you can get all the advantage of that 95% efficiency. If you want to make it more complex to fit your narrative or your political views, I have neither and I don't care for them, I just care for numbers at the end of the day.
44,071 PostsLatest Activity: Aug 08, 2026
