map40
Jan 18, 2023Explorer
Huntindog wrote:blt2ski wrote:I wasn't talking about the financial aspects (though that does't make sense either) but what Ramble was claiming that a certain amount of solar could totally replace non green power. Everyone thinks that solar will produce rated power. Those of us that have solar on our RVs, know that is not true...There is also a belief that a place like Phoenix is 100% perfect for solar.. Also not true. Though their is plenty of sunshine, there is also plenty of heat. As panels heat up, output drops. So when you really need maximum output from the panels to supply the AC, at the hottest part of the day, you will not get rated output.
Huntingdog,
Even HERE in the cloudy rainy Seattle area. The few I know that have roof top solar, figure they've paid for the system in savings 3-5 yrs down the road. Use less of the power grid power. Maybe saving a salmon or two or three. Probably not......
The question I would have for your neighbors, is what % savings are they seeing? Yrs before an ROI hits pocket book? No one that I know with a roof top solar expects a full "I'm off the grid" from solar. On some days in summer, they do produce more than the use. I'm having personally a hard time seeing the bad part of residential solar.
It will help. Solve the WHOLE problem being discussed? NO! Every bit helps
Marty
As a case in point: My RV when at home in Phoenix has NEVER even come close to rated output. About 1300 watts out of 1860 is the best it can do. I have seen slighty more than rated output in May, at 9000 ft. where it is cool.
Agreed. Here in FL they sold a lot of systems and convinced people that they would "make money". Nope, they didn't.
Don't get me wrong, I have installed at least 10 solar systems in RVs for friends and I am a firm believer that if you need power Solar is a great resource. But also every system was designed with the posibility to charge from every concievable power source (DC 12V to 450V and AC 110-240V 15-50 AMPS) because we know that solar on it's own is not enough, you need something else.
44,070 PostsLatest Activity: Jul 01, 2022
