RambleOnNW
Jan 18, 2023Explorer II
Huntindog wrote:blt2ski wrote:I wasn't talking about the financial aspects (though that does't make sense either) but what Ramble was claiming that a certain amount of solar could totally replace non green power. Everyone thinks that solar will produce rated power. Those of us that have solar on our RVs, know that is not true...There is also a belief that a place like Phoenix is 100% perfect for solar.. Also not true. Though their is plenty of sunshine, there is also plenty of heat. As panels heat up, output drops. So when you really need maximum output from the panels to supply the AC, at the hottest part of the day, you will not get rated output.
Huntingdog,
Even HERE in the cloudy rainy Seattle area. The few I know that have roof top solar, figure they've paid for the system in savings 3-5 yrs down the road. Use less of the power grid power. Maybe saving a salmon or two or three. Probably not......
The question I would have for your neighbors, is what % savings are they seeing? Yrs before an ROI hits pocket book? No one that I know with a roof top solar expects a full "I'm off the grid" from solar. On some days in summer, they do produce more than the use. I'm having personally a hard time seeing the bad part of residential solar.
It will help. Solve the WHOLE problem being discussed? NO! Every bit helps
Marty
As a case in point: My RV when at home in Phoenix has NEVER even come close to rated output. About 1300 watts out of 1860 is the best it can do. I have seen slighty more than rated output in May, at 9000 ft. where it is cool.
Actually I do know all about solar as we have 9000 watts of non-leased fully net metered solar on our roof covering 100% of our annual electricity usage.
Annual solar output is easily modeled for any location using the NREL program PVWatts:
https://pvwatts.nrel.gov/
Temperature coefficients have gotten better. Even a Chinese panel like the 580 watt JinkoSolar has dropped to -0.34%/deg C. Your flat mounted panels on your RV will have lower output than tilted panels facing south.
44,070 PostsLatest Activity: Jul 01, 2022
