- jerem0621Explorer II
Turtle n Peeps wrote:
jmckelvy wrote:
I assume it is gas powered? If so remove the Idle Air Control Valve on the throttle body and clean with carb cleaner. Also clean the throttle body and any passages associated with the IACV.
This is where I would go first.
That fixed my 4.6 Modular V8 in my Fabulous Town Car from a very similar issue… Only difference was mine would howl like a trumpet, and die, and idle rough.
Just a hint… disconnect the battery before you replace the IAC…
Could also be a fuel filter.. chances are you need to replace it anyway.
Thanks!
Jeremiah - Turtle_n_PeepsExplorer
This is where I would go first. - blofgrenExplorer
x2. My former work truck, a Ford Ranger developed an issue where it would not idle at all and it turned out to be a bad idle air control valve. - mikebteExplorerCarburetor shot and you need a new transmission.
Not really, plug into that baby and see what it's doing. - jmckelvyExplorerI assume it is gas powered? If so remove the Idle Air Control Valve on the throttle body and clean with carb cleaner. Also clean the throttle body and any passages associated with the IACV.
44,056 PostsLatest Activity: Jan 19, 2025
